best springs for ride quality (already have kyb agx shocks and rides BAD)
I need some help deciding which springs are best for ride quality only. I don't care about drag launches or cornering, I just want it to ride well. Plz help. I currently run stock springs. I would prefer stock height but would lower the car if necessary. The car is a 93 trans am with 02 front end conversion
Your gonna get guys that swear by BMR, and guys that love strano. I have some cheap gas shocks from KYB and run the BMR springs and have no problems driving my car. those are the only suspension mods i have done.
I honestly went with the springs that gave my car the looks, more than performance/handling.
But i think the eibach prokit has the best looking stance.
LS1TECH Sponsor
If you stock springs and the car rides like crap, lowering springs won't help because you've got a shock problem. I know you have AGX's, but that doesn't mean there isn't a shock problem....
__________________
18 SCCA National Championships in house, many more for our customers prove we know our stuff.Talk is cheap, results matter.
Check out our KONI prices, our Master Cylinder Brace, and new Xtracker Hub/wheel bearing upgrade kits!
Yeah, lowering springs have higher spring rates to compensate for the limited suspension travel, thus making bumps/imperfections more firm or even harsh. The best ride quality will come from your stock springs.
I've heard great reviews of the ride quality with Bilstein shocks.
Thanks guys for the responses. I actually found the biggest problem and as embarrassing as it is to admit, my tire pressure was really low. Rookie mistake which I am not by far, but an excellent lesson learned. When u hear hooves...
I have never had a car with the KYB's on them. However, having both a Bilstein HD stock sprung car and a Koni SA stock sprung car, both rode pretty damn well considering that they were 'sports cars.' Won't get a land- barge-Lincoln ride in an Fbody unless you find some really low rate, high travel springs.
You might have to play with the settings on the KYBs some more to dial in the right damping. I don't know what the curves are like for them, but since you have to adjust compression and rebound at the same time you might have to make a compromise somewhere.
