OMG spring install help with pix plz help
ok so i got the back ones on, then tried installing the front ones.... i think i got the wrong springs shipped to me from eibach... its an eibach pro lowering kit. back went in eh, wasnt too sure, and now when i get the springs on the front strut/shock, nothing lines up. check out the pictures... they appear to be the wrong springs, even the part numbers dont match up...
ok first picture, check the bottom of the BLACK spring, which is the Eibach spring.. the end doesnt match where the end of the stock one does. this in tune does not match up with the boot on the top of the strut and at the bottom of the strut. to me it appears to be one fit only...
now this picture of the sticker on the box labling it as 3870.140
now check the lable on the front spring 3870.001
now check the lable on the REAR spring which is already ******* installed 3870.002
me and my friend are doing this, and we cant see how we fucked up.. did we? or did we get royaly ******* fucked by eibach packaging guys? i need to know asap to decide wtf to do with my damn car. thanks alot guys!!
Well ya I know is supposed o be shorter. But look at the end of the spring coil. It doesn't match in position to the stock one. I got the stock one back on but I'll use Photoshop to how you what I mean about it not fitting. Nothing on the shock is adjustable so the spring only has one way to fit in the seats. Well the eibaxh one dits but then throws off all the bolts and nothing lines yp
You expect 2 different parts to have the same part number? Assuming 3870 is the part number, 001 and 002 are differentiators within that part number. According to Summit Racing, you have the right part numbers but apparently messed something up.
You can adjust the spring mounting pads on the struts to fit the spring just twist the bottom of the strut.
from your pic it looks like the spring is 180 out so just twist the mounting pad to where you need it.
to all everyone who helped. i owe you like money lol. i had NO ******* IDEA the bottom perch spun.. it was so dirty it wouldnt spin untill i ******* hulk smashed that bitch. so thank you all, this, is why i ******* love LS1tech. you get mustang ****, you get drama queens, then you get ppl that do what whis forum was meant for, to help and to educate. thank you all very ******* much. i will post pix when im done lol. thx again guys!
im gald to say i helped in that project. it was a beating, but fun. i have never lowered a trans am before. i have to say it was pretty easy once we figured out to spin the bottom perch. i dont own a ls1 or trans am (yet) but this project just makes me want one even more. thx guys
