eibach springs vs. stock for rear
i just put on new set of M/T 315/35/17 in rear of SS. Had Nittos before. M/T's are a bit wider. I am using eibach -1.5 What are the height and rate on the stock spring? If the car sits up an inch with higher rate it might work. Have not rolled the fender. Car is not used at track. Needed the M/T's in the rear because of 408 up front.
