Right Rear Tire Rubs LCA
I've been fighting this problem for a few months now. I have GM Y2K Vette wheels with 275 rubber. The car is lowered 1.5". I went to the track and wheel hopped pretty bad, and the right rear tire started to rub the LCA on right turns, but only with no acceleration.
I started with the obvious - the car is lowered, I need an adjustable PHR. Got that on, centered the rear end, still rubs.
If the rear end is centered left-right, there must be something allowing the rear end to move forward and backwards.
My next step will be adjustable LCA's, then if that doesn't solve it, I'll move to a Torque Arm Relocation setup with a poly bushing to eliminate any slack in the torque arm as well.
Anyone had an issue like this before? Any thoughts?
Since the panhard bar didn't solve the problem I would recommend looking into a set of off set control arms. The off set control arms use smaller diameter tubing and are offset inward. These can be seen here- www.umiperformance.com/2017OF
How much is actually rubbing? Is it just touching them control arms slightly? Do you have factory control arms?
I would have to think the factory LCA bushing are shot, allowing excess front/rear movement of the rear-end assembly causing the rubbing.
Either 1LE LCA bushings, or new LCA's with low deflection bushings(poly), rod-ends, or roto-joints, or a combination of the poly and roto, or rod-ends should solve it.
We have several different variations of control arms for a multitude of applications.
A listing of what we have to offer can be found HERE
