V6 Springs?
Old 09-29-2010, 11:53 AM
Restricted User
Zero4488's Avatar
Default V6 Springs?
Anybody got a brand and part number for v6 F-body rear springs....I can all the ones I am finding are the same as Z28 springs....I know advance auto used to have two different part numbers....now they only have one.....let me know....
Old 09-29-2010, 11:22 PM
Restricted User
Zero4488's Avatar
Nobody?
Old 09-30-2010, 12:00 AM
libertyforall1776's Avatar
If you want stock part #s, call a Chevrolet Parts or Service Dept.
Old 09-30-2010, 12:21 AM
HAZ-Matt's Avatar
That is because the 98+ F-cars all had the same rear springs. The front spring rate was a little softer on the 98+ V6 cars compared to the LS1s though... but the sway bars were significantly smaller.
93-97 V6 cars had the lower rate rear springs (and lower rate front springs compared to 98+ V6)...
The rates were 223 front and 95.4 lbs/in rear 93-97, while 98+ were 257 front, 114 rear.
The part number used to be 22077418 for the early V6 rear springs. I don't know if that is valid now.
Old 09-30-2010, 12:30 AM
Restricted User
Zero4488's Avatar
Already tried that....they wanted vin numbers.....
Well then advance auto ripped me off previously....cause last I check they had two different part numbers from a z28 to the v6....but thanks for the input.....
Quick Reply: V6 Springs?
