MOSER 9 suspension questions
Location: Home town Clive,IA current town FORT BENNING GEORGIA
hey guys im currently running a moser 9, awhile ago i blew up my 10-bolt. so i was forced in making the buy. i need a sway bar, and torque arm due to fitment issues but while im at it i would also like to through some LCA's and a PANHARD bar. could you guys give me some sort of input as two witch ones i need also on the TQ arm im running true duals and i need to know what i need to make it fit
While I'm not sure, UMI says that their regular full length TA works with Moser 12 bolts, as well as most 9" housings....doesn't explicitly say but I would imagine that most would work.
http://www.umiperformance.com/catalo...ptjpa7bml3uoe5
You can sort of see the difference in how the torque arm mounts in this picture:
LCA's...single adjustable...get the rotojoint ends...otherwise poly...and chromemoly
PHB...same deal...single adjustable (or double if you're really lazy)...and rotojoint ends...otherwise poly...and chromemoly
Now I'm assuming you like to launch the car for the straight line...get the LCA relocation brackets as well specifically for your Moser 9
check stranoparts.com...he's a sponsor and has everything you need.
I just put a Moser 9inch in last weekend in my car and I have the UMI adjustable torque arm, parhard bar and LCAs. Everything bolted up fine. I did have to beat in underneath the car because the torque arm was hitting a little over bumps but that was expected and no problem to fix.
All our items will work on the Moser 9" with the exception of our non-adjustable torque arm, which we don't recommend non-adj. for this rear anyhow. We do recommend adjustable panhard bar and control arms for that rear end. We have found the Moser 9" rear end to not sit center like the factory rear end and we use adjustable items to position it correctly.
For true duals you can run our #2205 torque arm. Here are some pictures of it installed with true duals- True Dual Pictures
If you have any questions please feel free to ask. Thank you!
Ryan
