Anyone have pics of Kenny Brown DD's SFC's installed?
Im thinking about putting these on my 98 Bird, but wanted to see a pic of them installed from the side and from underneath. I just wanted to be sure they wouldnt get in the way of everyday maitenence like fuel filter, transmission mount, torque arm mount, exhaust. My car has midlength headers, but other than that everything else is stock where the subframes will go. I dont have installation instructions. I wanted to find a pic so i could give it to the shop that welds them up for me.
You must have gotten them a LONG time ago, as Kenny Brown only made them for 3-4 years, back in the mid 90s. I have a set of them on my car, put them on around '98-'99.
These also look the same as the Hotpart ones:
http://rksport.com/main/part_detail....mdid=1&catid=3
"The Double Diamond Subframe Connectors improve the handling, feel and weight transfer of the 4th. generation Camaro. This unique design ties the front subframe, the rear transmission mount, the rocker panel pinch weld, and the rear subframe together to create a tight box that greatly reduces flexing. The Double Diamond Subframe Connectors mount and weld to five crucial points on the frame ensuring a strong bond between the subframes and the frame itself. Each unit is black powder coated for corrosion protection and a race look. Installation instructions are included. Professional installation is recommended. For all V6 Models Welding is required. WILL NOT WORK ON CONVERTIBLES<"
