suspention question looking for more traction with eibach prokit
Old 10-05-2010, 07:36 PM
meatyz's Avatar
Default suspention question looking for more traction with eibach prokit
my 02 camaro has eibach prokit and stock shocks it has subframe connectors and rear control arms im not looking to spend a alot being i am taking care of other things on the car right now but what do u guys suggest i can do to get alittle more traction without taking away the look of the car maybe just rear stock springs?
Old 10-05-2010, 08:44 PM
cookba's Avatar
you spelled suspension wrong in the thread name.
-eibach is pretty much just a lowering spring. What are your tire pressure set to? what tires do you run. basics
Old 10-10-2010, 11:55 PM
BS
BS's Avatar
When you lowered your car did you install LCA Relocation Brackets?
From the UMI website:
"Lower control arm relocation brackets reposition your instant center by changing your lower control arm angle for improved traction. Relocation brackets lower the rear of the control arm up to 3", a must for all lowered vehicles to correct lost suspension geometry. By lowering your vehicle, you are changing the lower control arm angle allowing the rear mounting point to sit higher than the front. This will, in return, cause wheel hop and a great deal of traction loss. Lower control arm relocation brackets allow you to correct this angle and gain back much needed traction. On a stock height vehicle relocation brackets will also work excellent to eliminate tire spin and wheel hop by changing the vehicles instant center point. Note: Bolt-on relocation brackets will not work with aftermarket rear ends.
Lowered Vehicles: We do not recommend lowering a 3rd or 4th generation F-Body without lower control arm relocation brackets due to the compromise in the geometry on the instant center. Brackets will significantly improve instant center position, eliminate wheel hop and increase traction. Brackets installed will also help 60-foot times of .10 or better, lower ETs and increase track consistency--a must for all lowered vehicles!
Non-Lowered Vehicles: Product installed on a stock height vehicle will also see a great increase in traction by lowering the rearward angle of the lower control arm, allowing more force to be placed on the rear tires. Relocation brackets have two settings to allow the lower control arm to be lowered either 2" or 3", depending on your preference. Settings are placed in a correct pattern that will allow use of all OEM control arms or any aftermarket control arm (brackets do not require a longer control arm.) Brackets installed on a non-lowered F-Body provide a .10 or better 60-foot; reduction and an increase in track consistency."
http://www.umiperformance.com/catalo...dex&cPath=6_85
