relocation brackets
relocation brackets
For maximum traction, is it best to lower the control arm to the lowest hole? Right now it's in the second to the lowest. Not sure if you can actually "hurt" traction by having it in too low of a hole. Thanks.
If you're having traction problems, drop the axle side lower and see if it helps. If your traction is good without the LCAs as far down as possible, dropping them further won't help anything and will hurt handling.
Moderator
Lower hole equals more bite, as long as you can hook
up what you've got to the pavement.
But too much and you can pick up some brake lift
or even brake hop. That's the trade with a fixed torque
arm.
arm.
