adjustable lca's with mini-laddar bar?
this may be a dumb question but i need some advise with my 8.8 swap. i'm going to delete my torque arm and do a mini-laddar bar set-up with a double adjustable control arm with rod ends going from a bracket on the lca to a bracket on the rear axle. being that this arm will be adjustable, will it make a difference if the lower control arm is adjustable? i would think i'd still want it adjustable but i'm just making sure. i'll be getting an aftermarked boxed lca for strength and ease of welding a bracket to. thanks!
and with this set-up, i'd adjust the lca to move the axle forward and backward to center the tire, and adjust the laddar bar to pivot it and change the pinion angle, right?
havent built 1 myself but all the ones ive seen the lca's are non adjustable and the upper links are adjustable. when u adjust the upper links the lowers will just pivot in the mount allowing you to adjust pinion angle
