abs inop and brake light?
Old 10-15-2010, 12:08 PM
im2fast4u98z28's Avatar
Question abs inop and brake light?
i know it's like a 6% difference in tire sizes that will make these lights come on. i'm certain that i've got more than that. only question is can i do anything to make these lights go off. i don't care if abs doesn't work, just tired of seeing the lights.
Old 10-16-2010, 04:12 PM
bump....
Old 10-16-2010, 04:55 PM
94T/A5.7LT1's Avatar
Maybe pulling the bulb from the cluster, only thing I can think of.
Old 10-17-2010, 10:37 AM
if i have no other choice i will, but can anybody tell me how the car knows how fast the front tires are going?
Old 10-17-2010, 11:32 AM
by the speed sensor that is the bearing hub. If your ever back there if you look right behind the steering knuckle where the bearing hub bolts to you will see the sensor plug. Since you have a tire diameter difference it will tell that one side is movie faster then the other. It can do the same if a tire is has low tire pressure.
Old 10-17-2010, 05:20 PM
hiltsy855's Avatar
You need to pull the ABS - use a delete kit from SJM or make your own.
Old 10-18-2010, 10:02 PM
CubanGT's Avatar
Just curious, if the delete kit is installed, the light will go away? Im asking because since the ABS doesnt work now.. but brakes work fine... it would be nice to clean up the engine bay a bit..
Old 10-18-2010, 11:03 PM
93camaro_zzz's Avatar
Can't you program the light out with HPtuners? I get the same thing running my 28" tire out back and the 26" up front. but I havent tried HpTuners.
Old 10-18-2010, 11:45 PM
wrencher
wrencher's Avatar
No
Never seen any programming available for the EBCM.
Quick Reply: abs inop and brake light?
