Practicing double flare fittings before SJM !ABS?
I'm going to be installing a SJM ABS delete kit soon.
What tubing do I need to get to practice double flares with my tool before I attempt it on the in car lines? What size and where can I find it? I've never done flares before.
Actually it is a simple procedure. I would get a quality flare tool, Imperial makes a very good 1. Then you need a good reamer to prepare the inner and outer edges of the tube. Here is a link to CC's site with pics. With a little practice you will become a pro at it. I also like Imperial's tube bender, which comes in very handy to when running brake/fuel lines in your car.
http://www.carcraft.com/howto/50919/index.html
