Front control arm removal
Got everything in the front end pulled out except for the damned lower control arm bolts. They come most of the way out, but then the flange on the head hits the boot around the inner tie rod end/rack, and there's not enough play to get it past it.
Also, mmmmmmm:
Also, mmmmmmm:
I was able to wiggle mine past the rack just push on the boot. If you can't there are only two bolts that hold the rack to the k-member loosen them then push the rack up. For the nut mine wouldn't break loose with penetrating lube and an impact so i just cut the shaft of the strut and pulled it out, but I was replacing the struts.
