wheel hop
wheel hop
I have tube k-member and lower arms, qa1 single adjust coilovers. Adjustable torque arm, non adjustable rear control arms and relocation brackets. Pinion angle is set at -2. Every time I go to track the car wheel hops real bad. ANY suggestions?
LS1TECH Sponsor
Compression damping in the shocks controls unsprung weight. Are you first sure you don't have a blown shock, that's a prime concern--and QA1's aren't known to be bulletproof. They may not be busted, and you must might need a lot more compression damping (more and more the case with more and more unsprung weight like bigger rear axles and heavier wheels).
You could try and change your LCA bracket setting too.
__________________
18 SCCA National Championships in house, many more for our customers prove we know our stuff.Talk is cheap, results matter.
Check out our KONI prices, our Master Cylinder Brace, and new Xtracker Hub/wheel bearing upgrade kits!
