GTO front sway bar delete
Old 10-26-2010, 03:21 AM
06GTOKID's Avatar
Default GTO front sway bar delete
I have a 06 GTO that I am making in to a full time track car. I was thinking about taking the front sway bar off. I dont know if it will help with weight transfer or not? Thanks.
What about the ABS? I have seen alot of people doing ABS delete to.
Old 10-26-2010, 07:45 AM
93camaro_zzz's Avatar
Taking off the sway bar will definetly help. Mostly people do the ABS delete because when they are running skinnies + Dr's/slicks, they are differenet sizes front to rear, so it will throw an ABS fault and sometimes mess up your braking, so they delete it. Also ABS delete is a slight weight savings off the front of the car too.
Old 10-26-2010, 07:27 PM
06GTOKID's Avatar
it does not work on the GTO. It was all over the road.
Quick Reply: GTO front sway bar delete
