How can I keep TA from kicking out?
2000 TA 4l80e Spohn Torque arm, adjustable Trailing arms, Panhard Bar running 285 Invo's. Alignment has bee done already. Car tends to kick out left during power accel when tires loose traction and during hard shifts. Can this be improved or just by product of more power than traction?
0.13
just my $ 0.02'
Johnny
My understanding is as follows:
I don't remember which one it is, but one tire lifts when the back compresses and the other when the rear lifts. That is because of the angular design of the panhard bar. The watts link, on the other hand, places equal power due to the lateral/parallel design. Instead of the one tire squatting while the other lifts, they act equally.
Again, I want to say that I don't have a complete understanding about the watts link. I hope this info is correct. If someone can chime in to correct or dismiss my info, that would be great.
It's all good. I'm not calling you out. I have this problem too in the events I race in. I'm sure it happens due to many reasons, but the better I can understand it, then the better chance I have at fixing it.
Update... during lil run with new Shelby Mustang it became appearant as T/A kicked out hard left towards it's rt front fender during 1-2shift that prob still exist. Any way seems that 10# of boost is enough to handle the Shelby...
PHB forces the body to shift when the rear suspension compresses or lifts due to one end being attached to the body and the other end to the body. Watts link allows the body to NOT follow an arc, but rather move up and down only- NO LATERAL MOVEMENT- NO rear "shifting" as the rear susp moves. Is THIS the kicking out the O P is referring to? I'm not so sure. I think the kicking out is actually his tires losing adhesion due to a lot of power being applied, shocks not keeping the rear tires planted, high cornering speeds or something along those lines(?).
