Starting Suspension
Starting Suspension
Have Qa1 coilvers and shocks coming, doing a BMR lowering spring in the rear, is this the type of panhard and lca i want for a drag only full weight camaro?'
http://www.byunspeed.com/product_info.php?products_id=2065{2}6{9}7{200}453
http://www.byunspeed.com/product_info.php?products_id=5023{2}6
If this is a drag only car, you might take a look at our torque arms and lower control arms. Our parts are made of 4130 steel, use aircraft grade rod ends, and are made here in house by us. Here are a couple of links to our parts catalog on our website. The first is our torque arm, and the second is our lower control arms:
http://www.madmanandcoracing.com/sho....aspx?itemid=4
http://www.madmanandcoracing.com/sho....aspx?itemid=7
Give me a call if you have any questions. Our phone number is 225-673-3533.
Well its drag only but will be getting a lot of street time. Guess i worded that wrong. I could care less about ride quality or turning. Its just a straight line car.
Since you're not worried about those things, then you still might be interested in our products. Alot of time, people that drive their cars on the street don't like using our torque arm because they get alot of road noise. Ride quality is still good, but we like our suspension pretty tight, so turning probably won't be what it was before. Give me a call. We can talk about some options for you.
