Tunnel braces?
Old 02-06-2004, 12:40 PM
DanoHB's Avatar
Question Tunnel braces?
Are these things worth the money? I have the Spohn brace on my car (bought for $30 on Ebay), but it hangs lower than my hedders. Can I take this thing off and leave it off? What is it's main function? I am thinking that if I need one I will probably get the BMR one because it doesn't hang as low at all. I just lowered my car 1" and now that brace scrapes on everything. Please help me figure out if I should keep it, or ditch it.
Old 02-06-2004, 01:47 PM
felton316's Avatar
Its worth less..... Just added weight. I had mine off for 2 years now, since it didn't fit with my aftermarket exhaust.
Old 02-06-2004, 03:39 PM
Dope's Avatar
I yanked mine too. I had the BMR one on an unlowered car and it scraped every speed bump ever. DO NOT GET IT, IT IS A WASTE OF $$!
If you're really insistant on trying one, I'll sell you mine for half price. It's got a nasty scrape or two at the lowest point. Email me dope@twelveinch.com
Dope
Old 02-06-2004, 03:43 PM
Dope's Avatar
Oh yeah, if you want to get one, get the Lakewood Driveshaft Loop. It doubles as a decent brace and does not hang down AT ALL. In fact, I would say it's higher than the factory brace. It actually goes over the top of the exhaust, not under.
http://fear.net/~dope/old_camaro/suspension/lakewood_dsl/overallview(not_mine).jpg
Big pic. I used it with stock exhaust and with FLPs and it wasn't even close to ever banging.
Dope
Old 02-06-2004, 08:03 PM
Fulton 1's Avatar
Most people either ditch the stock piece or install a DSL in the same location. I have yet to hear a good theory as to why you should keep it if its interfering with your exhaust, etc.
Old 02-06-2004, 08:06 PM
glitch77's Avatar
Get a good hard driveshaft loop. If you really want one, I'll give you mine for the shipping. It has no paint.
Old 02-06-2004, 09:21 PM
2w0s060's Avatar
Yea I would recommend just getting the drive shaft loop.
I spohn brace hangs lower because it is made to work with all aftermarket exhaust systems. If you do decide to keep a Tunnel brace on I wouldnt go with the BMR, it is straight and wont clear with most exhaust systems.
Old 02-07-2004, 02:31 PM
Jpr5690's Avatar
From What I Hear Its Suppose To Help With The Stability Of The Car I Dont Kow Too Much Out It But A Couple Of Guys Ive Spoke With Said Removing It Forom Their Otherwise Stock Cars Made A Measurale Difference In Handeling (bad Change) They Put Theirs Back On But On The Other Hand The Stock Piece Is So Flimsy I Dont See What It Could Do But Again Why Woould It Be There If It Wasnt Needed???
Old 02-07-2004, 03:28 PM
Ferocity02's Avatar
Useless.... If you want one just get a drive shaft loop, or make your own...
Old 02-08-2004, 09:12 AM
2w0s060's Avatar
I think it is a good idea to have something there rather then nothing. If you are going to spend the money prob best to just get the loop.
As for the tunnel brace being extra weight, I don't think that whole 5lbs is going to hurt you any. If that is the case, just don't eat at Mcdonalds before you hit the track
Old 02-08-2004, 08:56 PM
It's not mine! woo hoo!
demonspeed's Avatar
Just go with a Spohn torque arm with the drive shaft loop mounted on the front. It will take the place of the tunnel brace. You can't go wrong with the Spohn stuff
Old 02-10-2004, 08:18 PM
mean02's Avatar
The spohn hangs down too low.
Old 02-11-2004, 03:36 PM
2w0s060's Avatar
I don't think they would be the best for a lowered car. All you can do is totally ellimanate the tunnel brace. The aftermarket braces have to be bent like that to clear aftermarket exhaust systems.
So watch the speed bumps
Old 02-11-2004, 03:53 PM
Fulton 1's Avatar
Damn, that Spohn is LOW I'd be afraid I'd leave it behind on a speed bump in a lowered car.
FWIW, the Lakewood DSL mounts to the tunnel brace attachment but it goes over the top of the exhaust so no loss in ground clearance.
Old 02-11-2004, 04:00 PM
demonspeed's Avatar
Basically, that's the best setup because it's one peice. The loop, the torque arm mount, and brace all in one. Sure, it's low, but you gotta pay to play.
Old 02-11-2004, 04:04 PM
Fulton 1's Avatar
Assuming you're okay with the idea of using the tunnel brace attach points to mount your torque arm...
Old 02-21-2004, 10:31 AM
eswolfgang's Avatar
I did the SLP brace with the driveshaft loop, otherwise keep stock.
Quick Reply: Tunnel braces?
