pinion angle ?
pinion angle ?
Ok so I lowered my car about 1" and I was wondering if I need to adjust my pinion angle and if so what shoul it be set to. I have an adjustable t-arm and at factory height I had it set at -2*.
You need to get back under your car and check it again.
https://ls1tech.com/forums/suspensio...ion-angle.html
-1.5 to -2 degrees is generally a good starting point. You seem like you are already familiar with adjusting the angle but if if not our video can be very helpful to visualize the procedure.
