BMR Trak Pak and Subframe Questions
To anyone who can answer:
I have a 2002 SLP Firehawk which as many know comes with a lowered suspension as part of the SLP package. I have installed the BMR Trak Pak and welded in the boxed subframe connectors , the car plants like an animal .
Kudos to BMR!!!
Problem I am having is cross-member with the dip in it for torque arm keeps bottoming out when I hit bumps or scrapes like crazy on any incline.
BMR what can I do to avoid this ,has the extra weight changed the ride height?
Also the Torque arm was slamming into the tranny tunnel when i hit bumps, the installation shop had to weld braces between the cross-member and frame to stop the flexing of cross member when I hit a bump, that seems to resolve the Torque arm slamming into the tunnel and scaring the crap out of every passenger.
Any help is great!!
Kudos to BMR!!!
Any help is great!!
thanks guys, I called BMR and they were helpful . They actually do have a cross bar that doesn't have a dip in it.
The dip was built in to accomodate bigger exhaust systems so that makes sense. I think I will cut the member and put a new piece of pipe to get rid of the dip, I am hoping that 1 inch of clearance will do the trick. That was oked by BMR.
I will let everyone know the outcome.
