wat u guy use to lube brake caliper slide pin and brake pad ?
Im plan doing rear brake pad change, on my 97 camaro z28. I have few question
Any special tool I need ?
what do u guy recomment to lube the caliper slide pin( I need something that last long time and not seize up, something water proof )
and for brake pad also, something that water proof and does not melt when pad get hot.
Just tell me what u guy recomment to use to finish the rear brake pad job, thx !
No special tools required except for maybe a large c-clamp and an old pad to compress the piston back down.
For the pin, I would recommend some high temp synthetic grease and for the pads, some disc brake quiet should do the trick.
http://www.permatex.com/products/Aut..._Lubricant.htm
So, I snagged a cottle and its amazin stuff.
I was cruising through Amazon.com of all places and saw this link come up.
