Suggestions - Front Sway bar, Shocks - Calm Driving
My 1999 is in need of a front sway bar and, in the near future, shocks. The vehicle is a daily driver and will never see a track or racing scenario. I have been browsing the forums, but most recommendations do not seem to fit my needs due to the minimalistic requirements. The overall goal is to make the car comfortable to drive while maintaining a budget. My automotive knowledge is not great so please bare with me on any questions or suggestions. Does anyone have any suggestions for the "standard" driver?
Several threads note concerns about oddities in steering with only replacing one sway bar. With relatively relaxed driving will this still be a problem?
With all the sizes available, should I stick with stock on the notion that I do not plan to upgrade the rear sway bar?
Sway bar budget: $150 - $200 shipped
Shocks: <$400 shipped. Preferably closer to $300
The local oil change shop and a friend of mine have both indicated that the front sway bar is broken. Also, the car is not handling stability well in sharp or harder than normal turns.
Your front sway bar is broken?? Are you sure it's not just the end links or the bushings, both of which are prone to breaking (at least much more so than the actual bar)? I've never seen a sway bar completely fail....not saying it's not possible, just unlikely (sway bars act as torsional springs basically, they're made to flex without breaking). If you're planning on keeping the rear bar stock and it's true that your front bar is broken, I'd pick up a used WS6/SS bar (32mm) off of the classified ads or something, should be well within your budget.
The front sway bar on my brother's Camaro broke off at both ends, so it's possible. Like someone else mentioned, a used SS/WS6 bar would be perfect for your needs, and should run you less than $50. SLP Bilstein shocks also fit the bill for your needs. Those would be my recommendations.
Check the endlinks for old/damaged bushings and insure they are just tight enough to begin compressing the bushings. Check the frame bushings to confirm they are lubed and the frame brackets are not broken. I had a frame bracket bust and caused an oversteer condition. I replaced them with stronger aftermarket brackets. Maybe you can get the car on a lift and take/post a photo of the 'broken' area.
I'd stick with the current bar unless it is damaged. If the bar itself is damaged, search the classifieds for the same or consider getting the stock 32mm front bar instead.
Unless you're just taking your car to the drag strip I'd recommend keeping it on. Having an end-link break (effectively no sway bar) makes the entire car feel sloppy to me....I see others have different opinions.
Basically, if you're saying your car doesn't have the stable handling you want then it doesn't make any sense to take the bar off.
If you could get a picture from under your car to show us, I'd appreciate it. I want to see what happened.
