has anyone used 92 camaro struts on a 98 camaro
Old 09-11-2011, 11:25 AM
Rundeep66's Avatar
Default has anyone used 92 camaro struts on a 98 camaro
I'm trying to put 92 camaro stuts on my 98 camaro. any any pictures or advice please. i'm putting a big motor bbc in my 98 and the valve cover is about two inches from the strut tower on the driver side. i've heard people doing it but can't locate an article or picture.
Old 09-11-2011, 11:31 AM
technical's Avatar
4th gens do not have struts and therefore the lower mount is completely different between the 3rd and 4th gen. Not sure why the shock/strut is the important part. You would really need to change the spring if putting a heavier motor in the car.
Old 09-11-2011, 11:38 AM
DANSBIRD's Avatar
If you want some shocks... I just took my Bilsteins off of my T/A and will soon be selling them.
Old 09-11-2011, 12:01 PM
Rundeep66's Avatar
i'm trying to get the strut tower out of my way. the 92 camaro strut is at less angle than the position of the 98.
Old 09-11-2011, 06:09 PM
Shockwave179's Avatar
Pretty sure fronts won't work. 3rd Gen rears definitively work as I have them on my 98.
Old 09-11-2011, 06:12 PM
The Batman's Avatar
82-92 camaros have a completely different front suspension than the 93-02.
Old 09-12-2011, 10:27 AM
LS1Tech Premium Sponsor
BMR Tech2's Avatar
Yep, the rear suspension setup is nearly identical but the front is not.
__________________
T.C.
Sales Pro
BMR Suspension
(813) 986-9302
Like us on Facebook!
Old 09-12-2011, 05:29 PM
leadfoot4's Avatar
Do a search of 1993 ZL1 Camaro. Back in 1993, Lingenfelter Performance built a custom, BBC powered '93 Camaro for GMPP. All the "gear head" magazines had a chance to thrash the car, and write articles about it.
With respect to your original question, you might as well find an '82-'92 Camaro/Firebird donor car, and cut it off at the firewall, cut the front end off your '98, and weld the older front end on in it's place. That's how different the two generations of cars are.......
Old 09-12-2011, 09:19 PM
Rundeep66's Avatar
I talked to Pat at Race Craft and he is in the process of making another K Member that should clear big motors with a dry sump. he's also going to use a strut style shock so the shock tower can be cut back a little. Thanks guys
Old 09-13-2011, 10:13 PM
technical's Avatar
You're going to need more than just a strut and clearanced shock tower. You'll need to source the correct knuckle/spindle that will accept the strut and rack'n'pinion tie rod ends. You'll also need to fabricate the correct shock top to accommodate the correct strut angle.
With that much modification you might be better off installing a roll cage style front subframe. With that you'll have significant better clearance and much easier time installing a front suspension while reducing weight.
Old 09-14-2011, 06:11 AM
leadfoot4's Avatar
Very true.....
Quick Reply: has anyone used 92 camaro struts on a 98 camaro
