Mounting Brake Lines on Stock Rear - Question
Old 09-26-2011, 08:41 PM
105's Avatar
Default Mounting Brake Lines on Stock Rear - Question
I've almost got the car swapped back to stock from the 9". How are these brake lines and E-brake lines supposed to be secured on or around the rear? Can I just bend these lines however I want without hurting them? If someone could post pics of their stock setup that would be awesome.
Here is what I got so far.
from passenger side
from passenger side
from passenger side
From drivers side, I can see where the brake line bolts to the rear possibly
Old 09-30-2011, 06:53 AM
Fury_786's Avatar
the stock lines are terribly ugly...i used some 7/16" cable ties (zip ties) appprox 4 on each side to hold them to the tubes
i recently bought 2 new hardlines from the local parts store and bent my own lines which fit alot nicer for $8
Old 09-30-2011, 11:13 AM
105's Avatar
Well I shoved the lines down into the clips on the tubes and tapped them shut with a mallet. Is the brake line splitter supposed to bolt to the housing?
Old 09-30-2011, 04:12 PM
Fury_786's Avatar
on factory rears, depending on the brake setup, they do.
its not super important, as long as its not rubbing on anything
Quick Reply: Mounting Brake Lines on Stock Rear - Question
