How to raise ride height on front adjustable QA1 shocks?
Restricted User
So I have the QA1 12 way adjustable front shocks and I am wanting to raise it a little bit to help with my weight transfer issue. My question is do I need the special spanner wrench tool to turn the **** the springs sit on for lowering/highering it? Or can I do it with something else?
Yes you need a QA1 spanner wrench to adjust the height. The QA1 part # is T114W and run around $18.00 each. If your kit was installed with out the optional thrust bearing kit you will only get a small turn at a time so it will take a little to get the height up.
I hope this helps!
Ryan
I hope this helps!
Ryan
Restricted User
I hope this helps!
Ryan
I hope this helps!
Ryan
http://www.summitracing.com/parts/HAL-T114W/
Yes that'll do it!
IMO, I'd spray the threads above the spring seats with some type of lubricant, and wear a pair of grippy gloves.
Also, for example: if you want to raise it 1", raise the spring seat about 1/2", or 1/2" then move the spring seat up 1/4", and so on....
Try this:Measure from the bottom of the shock were the threads start up to the bottom of the jam nut, below the actual spring seat. Write this measurement down it's your reference point, so now if you want to maybe raise the ride height up about 1" you'll want to adjust the spring seat up about 1/2".
I hope that makes a little more sense.
Restricted User
