H&R Guys Inside:
Old 03-09-2004, 02:12 PM
SSInnovations's Avatar
Default H&R Guys Inside:
I am just wondering what type of shocks you guys with H&R springs are using? Also, how’s the ride in your opinion? And does anybody know the spring rate on them?
Old 03-09-2004, 07:58 PM
trackbird's Avatar
1. Koni DA's
2. Depends on the shock settings, "moderately stiff".
3. 648 in lb/ 257 in lb (F/R, per my calculations)
Old 03-09-2004, 10:06 PM
roy
roy's Avatar
Revalved Bilsteins to handle the massive spring rate
Old 03-09-2004, 10:20 PM
Are these springs progressive?
and
Are all revalved Blisteins equal?
Old 03-10-2004, 07:23 PM
trackbird's Avatar
1. No, they are linear rate with a tender spring (look like a progressive, but the weight of the car crushes the "soft part" into a spacer.
2. Probably.
Old 03-10-2004, 10:15 PM
roy
roy's Avatar
I would say all revalved Bilsteins are not valved equally . There valved according to the spring rate andwhat you want to do with it. Unless i miss understood your question
Old 03-11-2004, 12:06 PM
HydroDesign's Avatar
how much cheaper are the revalved bilsteins than the Koni DA's? I hope alot!
Old 03-29-2004, 06:59 PM
00PewterSS's Avatar
I am trying to buy springs and I have found a lot on information on here helpful. I decided to get G2 springs... then found they are on back order indefinately.
So I'm thinking of H&R springs. The springs mentioned on this post are 1.25" drop Sport spring?? If so they advertise the rate is 25-30% more than the stock springs. I called them today, and they refused to tell me the spring rates (kinda annoying).
Are their Sport springs the ones stated here at 648/248?? Are these progressive rates?
Thanks.
Old 03-29-2004, 08:26 PM
trackbird's Avatar
Roy, thanks for catching that one. I read that as "Are revalved Bilstiens equal to Koni's?", not are they all equal. Oops.
Quick Reply: H&R Guys Inside:
