What ds loop to use with tunnel mount tq arm
I bought a umi tunnel mount tq arm awhile back and for some reason I didn't get the one with a ds loop.
Too late now, but is there an aftermarket bolt in loop that is recommended to bolt in between the body and the tq arm mount? I've looked at the lakewood and granatelli pieces and I am thinking that one of them will be my best bet. Also I will be getting a bigger aftermarket aluminum drive shaft so I need one that is big enough. Any suggestions? Thanks
Hello,
All the drive shaft loops on the market are going to bolt into the same four mounting holes used by the tunnel mounted torque arm. So unfortunately the only way to get a loop on that car is to change out the front crossmember of the torque arm for one that has a loop built into it. The crossmember you have now could be easily sold in the parts section.
Below is a link to torque arm items we offer, look at part #2201AS and 2203AS.
UMI Torque Arm Items
If you have any questions please ask. Thank you!
Ryan
Ryan
