Lowering my car with Stranos...which PHB to choose??
Old 11-08-2011, 02:28 AM
jthunderz28's Avatar
Default Lowering my car with Stranos...which PHB to choose??
Finally gonna get my car lowered after my Strano Springs have been sitting collecting dust.A lot of folks have been telling me an adjustable PHB is necessary due to the rear end not centering after lowering the vehicle.
I went to UMI"s website and there are a bunch of different adjustable PHB's??
I want my car to be as quiet as possible but yet to be as centered and handle well obviously..
Which PHB should I choose??? single adjustable? Double adjustable? Polyurethane bushings?? I am completely lost.
Old 11-08-2011, 02:48 AM
82cetuner's Avatar
I would get a on car double adjustable one makes things alot easier, poly bushings would be good will stiffin the ride a bit.
Old 11-08-2011, 07:31 AM
UMI Sales's Avatar
Good morning JThunder.
As you mention, with lowering a car an adjustable Panhard (PHB) Bar becomes necessary if you want to optimize your combination. That eliminates the non-adjustable - which is still a fine choice for a stock application by the way.
Single adjustable allows you to optimize but must be dropped at the adjuster end to perform the adjustment. This style is great for daily drivers with combinations that aren't going to be changed often. If you're going for lowering springs, the PHB, then drive it for years without touching it, this is a great option.
Double adjustable is adjustable on-car. We sell these to customers who are always adjusting, changing combinations, etc. Makes for an easier time.
As for bushing choice, poly bushings are the entry level (yet still good) performance improvement choice. They give a tightened ride at a reasonable price.
Roto-Joints are a hybrid of rod-end and soft bushing. They function like a rod end but have the damping of a Delrin race. They're kind of the best of all worlds.
Rod-ends offer ultimate performance at the expense of a bit of noise. We sell a pretty equal combination of all the styles, it all depends on the application.
For a daily driver, I'd recommend single adjustable with poly bushings. P/N 2019. Just a little hint, we'll be offering a sale price over the Thanksgiving holiday. Check our website for details...
Good luck with your build. Your car will sit nice w the Stranos.
ramey
Old 11-08-2011, 11:34 AM
Thanks for the advice, that helps a lot. PM just sent to you.... about that Thanksgiving sale coming up.
Old 11-08-2011, 01:12 PM
Nowhereman's Avatar
Get the PHB that has a roto joint and one poly joint.
It's quiet and works great.
Old 11-09-2011, 12:49 PM
I was researching some more and I heard that the roto joint helps as well.
Appreciate the info
Old 11-10-2011, 06:11 PM
99Bluz28's Avatar
I've never had a issue with A phb being noisy, IMO just get one with rod-ends, on both ends.
FYI, GlobalWest has a nice one with spherical bearing on one end and a rod-end on the other end. It's on car adjustable on the rod-end side.
pm sent.
Old 11-11-2011, 01:23 PM
libertyforall1776's Avatar
The ideal, AFAIK, is a Watt's Link, not a replacement PHB...
Old 11-11-2011, 01:36 PM
99Bluz28's Avatar
Yeah, but not everyone wants to spend the money to buy a watts, or the time to set it up.
Old 11-12-2011, 02:10 AM
01ssreda4's Avatar
I like the Founders unit.
Old 11-12-2011, 02:42 AM
TruBloodTransAm's Avatar
I just ordered the Watts link, should be getting it next week. Supposedly there is a very noticeable difference between the two.
