A arm help?
A arm help?
I'm thinking of buying a some a arms but I see that they have adjustable ones, whats the purpose? The only thing I want them for is to drop some weight little by little. Also if say I only bought upper ones or only bought lower ones will everything bolt up just like a stock piece? Thanks
Hey Vandyke. Our uppers weigh in at about the same as stock. The advantage is strength, appearance and bushing/rod end options. Handling is improved by improving the mounting whether it be polyurethane or rod end. As our website literature mentions, alignment can be tricky with rod ends but can also result in awesome handling with the correct tuning. Polyurethane non-adjustable is a great general upgrade.
Our lowers can remove up to 8lbs total (4 per side) depending on, again, which mounting system you select. Roto-Joints add weight but offset that with great performance and are still lighter than stock.
In summary, if you want to go on a diet, choose the lowers carefully. Add the uppers if you prefer a complete package.
http://www.umiperformance.com/catalo...Path=7_137_103
Our sale is on so now's a great time to order. We're in here today on Black Friday to help you select. Give us a call. Shopping at UMI is way better than standing in line at Bath-n-Bodyworks...
ramey
ramey
Definately better than bath and body works. My mom left at 7:30 yesterday evening equipped with a taser lol. The car is gonna be mainly a drag car that I take out on weekends so the handling part isn't really an issue and I don't think 8 pounds is really gonna justify the cost at this point with all the other little things I need to do. How much weight will I drop going with a K member and the lowers. Also do you sell a panhard bar relocation kit? Im hoping duals are in my future.
We have packaged kits for the k-member and lowers. The total combo saves around 33lbs, a bit more with CrMo tubing, a bit less if you get Roto-Joints instead of rod ends.
http://www.umiperformance.com/catalo...cPath=7_137_96
Yes, we do indeed sell a PHB relo. Our site has some good install pics if you click on "larger image".
http://www.umiperformance.com/catalo...roducts_id=289
Have a good day.
ramey
