LCA reloc bracket/stock LCA's?
As of now I'm getting a bit of wheel hop under hard acceleration from a stand still, and it seems the answer is going to be going to a LCA relocation bracket and possibly new LCA's. My car is lowered with strano springs and yellow Koni's. My question being if I was to get just the relocation bracket, can I re use the stock LCA's or should (more like need to) I to swap over to an adjustable LCA? I've searched and it seems most people upgrade to adjustables as they have upgraded rears or bigger tires, but I'm on a 10 bolt, and 275/40z/r17 size tires.
Ok, the only thing I was wondering about is if there is a need to have them adjustable? It seems that's mostly for larger tires or different rears if I understand correctly? Thanks for the quick reply.
LS1Tech Premium Sponsor
There are people who use the factory control arms with the relocations, yes. The purpose of the relocation is the increase the control arm angle, so the benefit will still be there even with the factory control arms. Ideally, you would like to replace the flexible factory LCAs because of the bushings and lack of rigidity to their design. If you see yourself going to an aftermarket rearend, then I would certainly go with the adjustable versioins over the fixed length.
- Kevin
- Kevin
