Finally Posting Pics of Lower Perch/Heater Hose Setup!
Well, I made this switch probably sometime back in September, but between work (and continually forgetting) it took me a while to get some pictures and even longer to remember to post them up here on LS1tech.
I know there have been questions in threads in the past asking for pictures of Koni's on the lower perch and the heater hose mod in the back, all with stock springs. I finally started digging through my pictures and I'll put a few up on here. Keep in mind the car wasn't the cleanest when I took the pictures, and I haven't had much of a chance to clean them up on Photoshop yet.
Before:
After:
I know the car wasn't super 4x4 to start with, but I think the new stance really helps the car out.
Thanks for looking!!!!
Before:
After:
Just as the last poster said, it's just the stock springs with the second perch on Koni SA's. The perch drops the spring by about .75", which in turns lowers the car by about .75". That way you get the suspension travel and lower spring rates of the stock springs with the looks (I suppose you could argue more benefits, but it's mostly looks) of a lowered car.
Ride quality is good. Actually, I installed Sam's 35/22 sway bars and new rear LCA bushings at the same time, and the ride quality in the front didn't seem to change. The ride quality in the rear didn't seem to be as good, but I think something was loose (I heard a popping sound in the back) and it honestly felt like something was binding (I think my PHB needs to be shortened up). I just felt good to have the car ready to go and being it was almost time for storage, I felt that I'd just take care of the rest of the adjustments in the spring, haha.
All in all, though, on smooth roads it drove awesome (those sway's and a good alignment made this car drive awesome) and on rough roads it only felt like the rear was getting slightly upset. Not a big deal and I think it's something that will be a simple matter to fix in the spring.
Mark.
If you've got adjustable rears and haven't experimented with them yet give it a try. And don't be afraid to go more firm on the shocks. The word "firm" scared me a bit from deviating anywhere away from the softest setting. But once I started playing with it I realized I should've done it a long time ago. At full soft the rear was "sloppy". At full firm it was more under control and just right. Granted, I'm nowhere near stock, but the point is experiment!
Mark.
Mark.
I think it is good advice to go a little firmer in the back though, I don't know if I've thought about changing it since the drop, so thanks!
And to the other question, I used Moog 1LE-style rear bushings. The stockers weren't really shot, but I'm sure that transmitted a little more feeling into the car as well.
Old thread bump, but can this be done with factory shocks or just the Koni's?
Just got the Z28 from my mother in law, and they put factory replacement shocks on last year. The front is harsh, like it has ZERO travel over bumps. This makes me think my FIL didn't install the setup correctly. It hits hard on bumps, almost like the shock is locked. And it sits high as a Giraffe's ***.
*HELP!*
*HELP!*
