Any qa1 guys have a problem going through upper strut mounts?
Old 12-19-2011, 10:22 PM
SPRAYED 01's Avatar
Default Any qa1 guys have a problem going through upper strut mounts?
Last year I put qa1s on my 01 ta. I've got maybe 1k miles on them and both the rubber upper strut mounts have failed. First the right side and now the left.
They are just tearing. I put new ones on when I did the struts.
What gives?
Old 12-19-2011, 10:55 PM
Homeless2bNY's Avatar
What gives?
send me some pics of what your talking about.
you use any washers or spacers?
coil over set up?
Old 12-19-2011, 11:01 PM
SPRAYED 01's Avatar
I don't have any pics. its Just the standard qa1 setup for an fbody with the front struts and 275lbs spring, rear qa1 shocks with stock springs.
I don't run spacers just the standard washers they give you for the nut at the top
Old 12-20-2011, 08:01 AM
LS1Tech Premium Sponsor
BMR Sales2's Avatar
I am pretty sure your issue is that you don't have the rubber washer piece that sits on the top of the stru mount to spread out the load. Without that piece it puts all the load in a very small area which leads to failure. Here are a couple pictures of what I am talking about.
Attached Thumbnails Any qa1 guys have a problem going through upper strut mounts?-strut-mount.jpg   Any qa1 guys have a problem going through upper strut mounts?-strut-mount-2.jpg
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Old 12-20-2011, 08:58 AM
SPRAYED 01's Avatar
Which part is the washer in those pictures? The large part in the left picture?
Old 12-20-2011, 09:23 AM
BMR Sales2's Avatar
Yeah it is the picture on the left. That piece sits on the top of the strut mount in the right picture. You may want to pull yours out real quick and verify that piece is there.
__________________
Glenn ***
Sales Tech
813.986.9302
Old 12-20-2011, 09:26 AM
SPRAYED 01's Avatar
I don't think it is. Is that supposed to come with the new mount or do you get that seperate?
Old 12-20-2011, 09:32 AM
BMR Sales2's Avatar
They generally don't, most people will reuse their old one or buy a new one from the parts store. If you need one here is the brand and part number of one I quickly found, RAYBESTOS Part # 5201160.
__________________
Glenn ***
Sales Tech
813.986.9302
Quick Reply: Any qa1 guys have a problem going through upper strut mounts?
