No breaks after rear end swap?
Ok i changed my rear end and after putting it back together my brake pedal is really loose its to the floor, but the thing is that i already bleed the brakes and still the same? I did do something bad though when installimg the rear end my friend put in gear without applying the break and he also put iit park by not applying thr brake and i hear a nasty sound after he did that?
Im really lost here not sure what is wrong? Any help i would appreciated
You probably need to bleed them properly. Of of the fitting might not be tight. You should have a leak if that is the case but a super tiny hole might make it hard to see the leak.
Does the car have ABS? If so and you pushed fluid back through the system you can ruin an ABS unit quite quickly. I would guess you just need to get them bled and it will solve the issue.
Well i forgot to add this to the story, when i did my rear swap i had my wheels on the air and my friend put it like 3 times in gear without aplying the brakes and heard loud grinding sounds not sure if it has nothing to do with it?
Also accordimg to the mecanic he thinks its thr front brakes not the back??
Ok so i bleed them but i went to a local mecanic and he said he bleed them and that no air came out????
Since i didnt do it not sure but now that im thnking i think it wasnt? Did u have to take out the wheel or only moved the wheel ??? How did u do it or has the proper way to bleed them so i can give it a try?
Also my e brake is kind alose i know it has something to do with the drum that goes inside the disc but not sure how to adjust it
