Old 04-25-2016, 05:01 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Steering and Suspension Guides
Print Wikipost
Bad power steering fluid leak, need help!
Old 02-17-2012, 11:12 AM
Striker's Avatar
LOL thanks for the pic! Jeez, now I don't know if it's the dexcool issue I have OR if PS fluid has gotten in there.....I do have some light build-up on the coolant stick......
Old 02-18-2012, 08:30 PM
Save the manuals!
wssix99's Avatar
Post a pic of what you have and we can take a look.
Old 02-19-2012, 11:25 AM
Striker's Avatar
Will do. Worse case scenario, IF i do have the two fluids mixing, what's the solution. I wanna keep the car as stock as possible, so probably just replacing everything with new oem parts?
Old 02-19-2012, 08:41 PM
blue95's Avatar
If you have a power steering cooler, that's where the mix would have happened. Unfortunately (for those wanting to keep their cars 100% stock) this part is so prone to failure that, to my knowledge, GM no longer makes them. If you want to still have a PS cooler on your car, I recommend the Derale coolers available from Summit or Jegs.
To correct this, simply flush your PS system, install the aftermarket cooler of your choice, then fill the reservoir and bleed the system. You will also want to flush your cooling system as well. I did mine about a month ago. There are many useful threads on the forum you can use for information.
Old 02-19-2012, 09:01 PM
Save the manuals!
wssix99's Avatar
Yea, the stock coolers are IMO a really poor design.
You can check out this thread for details on a cooler option that a lot of us are having success with.
Old 02-20-2012, 08:53 AM
Save the manuals!
wssix99's Avatar
Sorry - here's the thread: https://ls1tech.com/forums/general-m...g-success.html
Quick Reply: Bad power steering fluid leak, need help!
