My suspension mods, Cut factory springs.
I have taken small steps in modding the suspension on my car. So far I am really happy with it. I started with both sway bars when I bought it, check my sig, that helped a lot with body roll. When I had the rear end out I boxed in my LCA's and swapped the bushings out to ureathane type. Next came the heater hose mod which helped get the car sitting level in the back. I was happy with that for a while but really wanted to lower the whole car.
I know a lot of guys will tell you not to cut the springs. I agree with that but, you can cut them and get the effect you want as long as you do not cut too much off. If you cut too much your car will ride like a log truck. In my case I only cut 1/2 coil off all 4 springs. It did exactlly what I wanted it too. I lowered the car just enough for my taste and made it ride like a sports car. I can now say that this car handles really close to my old 96 C4 Corvette. I still have the crappy stock shocks on the car, which replacing those, some subframe connectors, LCA relocation brackets, and adjustable panhard bar will be my next mods. As of right now I only have the $350.00 it cost for the sway bars.
Before cutting with just the heater hose mod
Look at the fender gap in this pic...
This is after the springs have been cut, with heater hose mod as well.
I just wanted to share for someone like me that does not want to slam the car to the ground, that is just looking for a better stance and wants the car to handle better.
Its pretty crazy how much stiffer the car does ride by just cutting off 1/2 coil, so I would NOT cut any more than that. If I want my car any lower I will have to buy springs.
Also if you decide to cut use a cut off wheel on an angle grinder, not a torch.
If you went ahead and cut a full coil, how much more of a drop do you think you would have got? That looks great, but it just isn't quite low enough for my tastes. I like the way the Sportlines make these cars sit, something close to that stance would be perfect.
I daily drive my car and I'm wanting to lower it pretty bad in the next couple of months, cutting the stock springs is something I've been thinking about. Do you think that cutting the stock coils and keeping the Decarbon shocks on the car for a while would absolutely equal a terrible ride?
Mine was lowered about a full inch. Sportlines (which are a 2" drop) make these cars way too low IMO. Just getting a jack under the car is gonna be a pain in the *** with a 2" drop, let alone driving over speed bumps and driveways, and there will be no suspension travel left, so the bumpstops will be getting quite a workout.
I think if you're gonna go through the trouble of cutting the springs (which requires taking the front shocks off) you should go ahead and replace the DeCarbons with at least a set of Bilsteins. The ride will be MUCH better since you won't be smacking the bumpstops constantly.
my car had sportlines on it when i bought it. they have always been too low for me. i think i would rather trade for some factory springs and cut them to my tastes. mine is not a daily driver so it could be down until i got the height right. your car looks good OP.
Would an adjustable panhard bar be REQUIRED for such a mod? The rear isn't being lowered that much. I'm sure it would be a good idea to get one anyway, but would it really be necessary?
You brought up some good points here, a 1" drop is definitely an improvement over stock, maybe I'll go that route instead, then follow up with some quality shocks, that's a much better idea. But like I said, I LOVE the look of the Sportlines 1.75"-2", but it's not really practical to drive it that low everyday. Also, what type of tool did you use to cut your coils?
No. Not only am I lowered an inch with the stock panhard bar, I have 315s on the rear and as far as I'm concerned it's just fine. If it's off center at all it's negligable, maybe a couple milimeters. Nothing you could even notice.
You dont need it but the stocker is stamped out pile of ****. Most aftermarket ones are made of steel tubing which will not flex us much, pluss they have poly bushings in them. Its just a good cheap upgrade.
Also I had the front struts apart in about 45 min. It wasn’t that bad to do. Just need some coil spring compressors.
Are you saying you cut off a full coil and the car went down 1 inch? I am pretty sure mine went down an inch by cutting off a 1/2 coil. It seems like my front wheel gap is about 1 7/8" and my rear is right at about 2". That’s laying a straight edge across the top of the tire and measuring to the fender/quarter lip. I can really tell mine is stiffer, I know the more you cut the stiffer it gets. If i get a set of bilsteins maybe i will cut another 1/4 spring off to give me a total of 3/4 coil cut off. I do not think the stock shocks can handle any more right now.
[QUOTE=96lt4c4;15796128]Are you saying you cut off a full coil and the car went down 1 inch? I am pretty sure mine went down an inch by cutting off a 1/2 coil. It seems like my front wheel gap is about 1 7/8" and my rear is right at about 2". That’s laying a straight edge across the top of the tire and measuring to the fender/quarter lip. [QUOTE]
Let me get this straight. You cut a 1/2 coil off all 4 springs, and the rear ones you eliminated the stock rubber spacer at top replaced with just the heater hose? My car is too low and looking at options.... I have cut springs for people before and have no fear of that....
Thanks for any info!!
