Rear Suspension Question
is the rear suspension really that important to upgrade on a DD? im thinking of getting a koni/strano setup for the front but i dont want to spend that much cash on the rear if it wont be worth it as much as the front. i would probably just put in new shocks (kyb) and do the hose mod on the rear
Get a good k member first. I think umi and bmr make them with poly mounts attach to the k member if you want poly mounts. Then a arms when you do the shocks and springs. Then sfc's then the rest. Dont get a shock tower brace unless you are pickin up the front.
