Best power steering upgrade?
Old 02-06-2012, 01:27 PM
99SSMOKIN's Avatar
Default Best power steering upgrade?
What are the best upgrades for the steering? I.e., pump, pulleys, linkage, rack set up
Old 02-06-2012, 01:28 PM
Zmg00camaross's Avatar
go manual rack haha. But if street car I would go with stock oem replacement parts
Old 02-06-2012, 02:47 PM
cranny's Avatar
A good external cooler.
Old 02-06-2012, 03:50 PM
UMI Sales's Avatar
What is your steering doing wrong in the first place? Feel? Overheating? Ratio?
What is the car doing wrong that you want to improve?
ramey
Old 02-06-2012, 04:20 PM
99SSMOKIN's Avatar
Nothing wrong other than 115000 miles on it I guess. It does seem to be making a crackling sound when I steer back n forth. Havnt quite tracked down the sound though. Anyway to see if the PS pump is good??? I think in 2001 they added a steering cooler to the Camaro v8 s. Didn't know if the stock setup is fine or if people upgrade it to perform better. It's my DD right now so I am not sure about manual steering.
Old 02-06-2012, 07:03 PM
99SSMOKIN's Avatar
OK..... crackling was just the steering linkage hitting a loose heat shield. Power steering seems to get hot.
Old 02-06-2012, 11:29 PM
sjsingle1's Avatar
turn one PS pump........and get rid of the stock PS cooler if you have 1.......and replace with a tranny cooler type...i use royal purple syn fluid.....the best you can do for upgrades
Old 02-07-2012, 12:29 AM
99SSMOKIN's Avatar
Is a tranny cooler type just larger? I dont have a PS cooler stock. How bout the rack setup? Any more confirmations on the problems of driving with a bad pump?
Thanx for all the info again
Old 02-07-2012, 05:48 AM
Anthony Williams's Avatar
Turn One pulley, you'll never have to pull the pulley to pull the pump again.
Old 02-07-2012, 09:42 AM
LS1Tech Premium Sponsor
BMR Tech2's Avatar
The Turn One pump is excellent and reduces fluid temperature and eliminates the power steering whine at full lock. Excellent upgrade for handling guys.
__________________
T.C.
Sales Pro
BMR Suspension
(813) 986-9302
Like us on Facebook!
Old 02-07-2012, 01:55 PM
2fresh's Avatar
is this pulley lighter than stock? just wondering if it will free up any hp as well?
Old 02-07-2012, 02:02 PM
truekoa's Avatar
I read that the Turn one pump is a little stiffer compared to an OEM replacement, is this true?
If it is, how stiff is the steering, what is it comparable to?
Old 02-07-2012, 02:26 PM
BMR Tech2's Avatar
Not the one to ask on this one. haha The car I drove with it never ran without it and it had a brand new rack so there was no back-to-back comparison for me. And, at the time, I was driving a '99 Trans Am, so it absolutely felt stiffer. What I do know is that it pushes the correct amount of power steering fluid and doesn't overexert itself like the factory pump. This could potentially mean it is smoother.
- Kevin
__________________
T.C.
Sales Pro
BMR Suspension
(813) 986-9302
Old 02-07-2012, 05:21 PM
99SSMOKIN's Avatar
Just checked out turn one's website. That's the way I am going. Great info
Old 02-07-2012, 05:31 PM
mitchntx's Avatar
An alternative is PSC www.pscmotorsports.com
Send them your pump and for $100 or so, you get a pump rebuilt and revalved just like teh TO pump.
Used a bunch of them.
Quick Reply: Best power steering upgrade?
