is this a problem?
is this a problem?
hopefully the pic is clear enough. after giving up on removing the front springs myself i took them to a mechanic and had the spring swapped over for 20$ each. i noticed one of the spring ends doesn't butt up against the black plastic piece, is this going to be a problem? i don't want to put them on and then pull them back out if its not correct.
