LCA angle
LS1Tech Premium Sponsor
Those photos are hard to judge the angle in them because of the perspective, but you can indeed increased the control arm angle. You won't find anything off the shelf, but if you take it to a good chassis shop, they should have no trouble making a custom one for a reasonable price.
- Kevin
- Kevin
ramey
I will try to do that when the weather permits again. I am pretty sure its almost level its barely slanted downward maybe a 5 degree slant or less. Before the relocation brackets the back was higher than the front of the LCA.
Besides having some other longer relocation brackets. What else will give me more of a slant. Its no where near stock at this point. Should I just raise the front of the car?
From you sig I couldn't tell, do you have a factory rear?
And, are you having traction trouble due to the angle? Or is it just that they should be pointed downward...
ramey
Trying to get straight driving traction not even racing traction. Its a factory rear. I will go to the shop to see if they can get than angle but to me its really almost level. Maybe a 5-10 degree tops angle.
Raising the front of the car would help get the angle but I'd like to investigate a bit further.
ramey
ramey
If you like the way the car sits, don't sacrifice that for the angle. The amount of money you will have to spend to get the car to change its stance so you have extra LCA angle is much more than you would spend to have custom LCA brackets made. As for shocks, what are you running now?
That's my opinion.
- Kevin
