traction
traction
I have an 05 goat. Gonna keep it stock except a dyno tune. What suspension upgrades will help with launching? Also with stock 17" rims what is the widest tire I can stuff in back without rolling the fender?
LS1Tech Premium Sponsor
As for tires, I wouldn't go wider than a 245, personally, but some people run wider tires out back for the track. The widest you can run without rolling the fender will depend on what your rear wheel offset will be, but a 295 is about as tight as you're going to get back there before having to notch the rear control arms and CUTTING the fender lips out.
DB001
- Kevin
Thanks for the help. Just wondering why u think I should leave my tires the same size. What tires would u recommend? On my o4 I had drs but I want a good street tire that can be used at the strip
You want to keep it stock, but pay 500$ for a dyno that will do basically nothing on a stock car , and add $$suspension for launching. Which isn't going to be impressive or help much at all with not a single bolt-on. The stock suspension on f-bodys is solid as it is. Especially if you aren't adding any paticular mods. Spend your money elsewhere.
A 275 is a good size tire, but that really isn't a recommended tire size for that wheel, which is something I avoid. Traction is mainly generated by the firewall so whenever you run a tire too wide for a wheel, it will bow the side wall out and the tire will decrease in its effectiveness. Have you searched for some 16-inch BMR 3-series wheels? They will bolt right up and are cheap. Perfect for a set of Mickey ET Streets!
- Kevin
As far as the tune goes I am looking to eliminate skip shift and change shift points etc. Not looking to gain tons of power. I am not looking to turn my car into a drag strip pig that has been altered to no end. I have cars that I feel are historically important and like to leave them stock. I have a 96 impala ss that is 100% stock and always will be. I had an 04. Goat and hated the wheelhop. It is not all about et with me. I will enjoy the car more tuned and without wheel hop. If I gain a tens or 2 great.
