Wife wiped out the V into a curb...pics of damage
So anyways, yesterday my wife gets caught in the snow downfall on the way home and loses it and slides into a curb. doesnt tell me anything and today i was on my way out and as im leaving down the side street i notice that the steering wheel is cocked at 2-3 o'clock when driving straight and i know that something is definitely wrong. I go straight back home and get out to see a big *** chunk missing from the wheel edge. I know she hit something like a curb. I confronted her and she said she wiped out coming down a hill and slid sideways into a curb. So i pull out my jack and take the wheel off, I didnt notice anything damaged and even compared it to the drivers side but to me everything looked straight, but its definitely NOT. anyways its really hard to control the car the more city speeds you go (like even 40km/h and more) and when i hit a bump like a sewer cover, the car does a weird sloppy motion...
Anyways, from my understanding, the upper control arms will NOT bend correct, that will only break due to it being aluminum? How about the hub because I saw that is aluminum aswell...I'm just trying to rule out anything that may be damaged because I dont want the mechanic to hose me when i can tell him that part only breaks and doesnt bend... and I tried gmpartsdirect and they dont put part numbers, im trying to see what parts/part #'s from the base cts and the cts-v are interchangeable.
what are youre guys suggestions of the culprit? And all pics are of the passenger rear wheel
It does sound like something is bent, but I can tell you that I slid into a curb and damaged a front wheel beyond repair a couple of years ago. Surprisingly, nothing else was damaged except the alignment was way, WAY off afterwards. I had the same thing going on with the steering wheel being at 2-3 o'clock when driving straight.
wrencher
I see quite a bit of this everytime the snow flys.
You would be suprised what bend vs breaks.
I've seen the spindles bend or even crack around the wheel bearing.
Sometimes it's really hard to tell intially what all is damaged.
I have had wheels bent on the hub so they dont track strait any longer as well.
I bet your adjusting link @ the least is bent.
Need to check the alignment of all the bushings to individual componets & that can help point you to bent parts.
My dad did the same thing last winter in his G8. He took it to the dealer and it needed upper and lower control arms for the passenger front/rear wheel, two new wheels, and a new wheel bearing for the front wheel. Alot of damage occurs when a 4,000lb vehicle comes to a sudden stop against a curb. Best of luck.
