'99 Z28 - Front Hub Bearing Assembly Replacement
'99 Camaro Z28 M6 w/235K miles
I'm replacing front brake pads and rotors today. While changing the driver's side set, I notice that I can hear a slight clicking sound when I rotate the center hub assembly. I assume that this means the internal hub bearings are beginning to go bad?
Do I need to replace the hubs on both sides? I don't hear the same sound from the passenger side hub. Just curious if they should be replaced in pairs?
Thanks
Bill
Thanks
Bill
I've never repacked wheel bearings on an f-body, but I have done it on several other cars and that usually is sufficient to fix the problem. Pull the bearings out and clean them off in a parts bath (or have a shop do it) to get all the old grease out. You could probably do it in a coffee can with some parts solvent and an old toothbrush...just leave them to soak for a while first. Once you clean out the old grease, wipe them dry with a clean shop rag and let the solvent evaporate (you can spray them with some brake cleaner to help, but be sure to let that completely dry before proceeding). Check for galling, pitting, or heat-discoloration in the metal of the roller bearings themselves. If you don't see any of this then repack the bearings with fresh grease. This is just a matter of pressing fresh grease into the bearing cage with your fingers. It's messy, but very low tech and easy to do. Wipe out the old grease from the inside of the bearing races in the hubs as thoroughly as you can with rags/paper towels before replacing the freshly packed bearings. That's all there is to it!
He's doing a brake job, but he's asking about wheel bearings not brakes. With the wheel off and disk still in place, tighten down the lugnuts (careful not to muck up the cone part on the ends, I'd say put them on upside down, but that's hard to do with the threads for the plastic lugnut caps in the way) and see if you still hear the sound. It could just be play from the disk without the clamping force of the wheel on it. On the other hand, your car is high mileage and may need the front wheel bearings repacked.
Thanks guys. I'm pulling together the parts to rebuild the front suspension, so I'll buy the driver's side hub also. Sy99T/A is correct .... it's a bolt in hub assembly.
I had the brake rotors and brake assembly stripped off of the hub when I spun it and heard the slight clicking sound. I'll check the passenger side again too when I get closer to completing the front suspension replacement.
"+1 For both of these. The whole front end could use a rebuild anywhere over 200k."
Yeah ... I've got the bushings for the front end, new tie rod ends, sway bar links ... I'll probably replace both hubs since the one is bad. I'm just trying to decide if I want to lower it while I've got it all apart. This is my daily driver, and I'm a little on the fence as to how much money I want to put into it.
Thanks.
Thanks.
