Sway bars
Old 03-04-2012, 10:53 PM
CRIMSON CAMARO's Avatar
Default Sway bars
Hey guys, wondering if u guys can direct me in the way of some performance sway bars for an 01 Z28. Also maybe some good lowering coilovers. Thanks guys.
Old 03-04-2012, 11:01 PM
ANTICOP RAM AIR's Avatar
search... you will get a shitload of opinions... figure out what youre gonna do with the car and make a logical decision that fits your budget...
Old 03-05-2012, 01:15 AM
need4fun2469's Avatar
look up Strano
Old 03-05-2012, 02:03 AM
Going in a straight line is ok but I prefer outhandling my opponent and taking my corners fast. I have edelbrock headers and Magnaflow exhaust with the SLP lid. I got me some poly bushings but im waiting and researching because I want to do it all in one shot
Old 03-05-2012, 02:32 AM
2QuikTA's Avatar
www.stranoparts.com
All you need to know.
Old 03-05-2012, 07:43 AM
z28bryan's Avatar
Basically you want the strano set.
What poly bushings exactly are you planning to install? Not the LCA's I hope
Old 03-05-2012, 09:48 AM
Thank for that strano tip. Im lookingnot into gettingthe the Bilstein shocks/ eibach springs lowering combo. Yeah its the lower control arm bushings. I think mine are really worn out. My engine doesn't shake but for some reason when I turn or brake at highway speeds, the body rattles a bit. Im thinking its my LEA bushings and if not that then its my sway bar. Maybe its twisted. Idk. What do u guys think.
Old 03-05-2012, 09:49 AM
Damn spelljake check. Sorry, I meant LCA bushings.
Old 03-05-2012, 09:50 AM
Old 03-05-2012, 10:33 AM
z28bryan's Avatar
Yeah I don't know if it's the bushings, but going to poly will only increase noise transfer. Rubber is best for noise dampening.
Another thing is poly will cause your axle to bind.. which is ok if you want the LCAs to act like a swaybar. Generally you want your swaybars to do that job. Only time I think poly rear LCA bushings added to the stock arms would be recommended is if you are drag racing.. where you usually want a real stiff rear swaybar to keep the rear stable on a launch.
I've got some solid moog bushings I've had forever that I want to install this year. They will allow the axle to move freely
Old 03-05-2012, 01:57 PM
UMI Sales's Avatar
UMI sways work great for your type of application:
http://www.umiperformance.com/catalo...roducts_id=292
Strano springs are pretty sweet.
ramey
Old 03-05-2012, 02:01 PM
Oh ok. We'll when would u recommend using poly bushings. I've heard they perform better and that they take wear and tear really good, but I also heard they make ur car feel stiff. I want smooth. Not too soft not too hard just right.
Quick Reply: Sway bars
