Help Troubleshoot Suspension
When driving 55mph the steering wheel shimmy's back and forth with a slight bounce in the rear. At 65+ same shimmy in steering wheel but rear end bounces a lot more.
At 55+ whenever I turn slight right or change lanes I get a vibration sound, an intermittent Whirring over and over coming from the front end as well as vibration in the steering wheel.
What I have noticed when looking under the car is 1 of the 4 rims have 3 weights while the others have 1 as well as my LCA bushings needing replacement.
Could the bounce be from a bent rim due to wheel balance? Could the LCA bushings contribute or be the cause of this rear end bouncing?
