ABS Block Threads Stripped
Old 03-19-2012, 10:50 PM
acertx's Avatar
Default ABS Block Threads Stripped
I removed the lines coming from the Master Cylinder to the ABS block to do a spring/shock install and one of the threads in the ABS block is stripped. Getting donor lines isn't a problem being in Texas, but I really don't want to have to deal with replacing the ABS block. Does anyone know of the size tap I need to clean up the threads? I would think this is a very simple fix.
Quick Reply: ABS Block Threads Stripped
