Front lower A-Arm removal help.
Old 03-22-2012, 07:18 PM
techls1's Avatar
Default Front lower A-Arm removal help.
I decided to do a major overhaul of the suspension on my 99. After taking most of the front end apart I have found that ll the joints are shot. Additionally all the bushing are beyond dry rot. The problem I have is that I have no idea how to remove the rear bolt on the lower control arm. I was able to remove the nut off the bottom but I am unable to even have the bolt budge at all. Since it is in a tight corner I cannot get in there with a cutoff wheel. I have tried a few made for metal sawz-all blades and have had no luck. Short of a cutting torch does anyone have any suggestions?
Additionally has any one painter their's with Rust-o-leum? I have heard good things about it but was wondering if anyone has had any luck.
Any suggestions are appreciated.
Old 03-23-2012, 07:58 AM
themealonwheels's Avatar
Try raising the ball joint end of the arm, it's possible the bolt in the rear is binding because the bushing is at a slight angle in the k-member slot. I did this and found the bolt could be removed by fingertip. Note, this is on a 180k miles 2000 B4C! Once you raise the ball joint end to almost level, set a screw driver or chisel on it and "massage" it a bit.
I used Rustoleum on the arms once they were out, they're certainly not scratch proof, LOL! Once I touched up the places it was scratched on installation, it looked great. Good Luck!
Quick Reply: Front lower A-Arm removal help.
