Brakes not holding at staging light - LS1TECH
Thread Tools Search this Thread
Old 03-31-2012, 05:37 PM   #1
Skentch's Avatar
Default Brakes not holding at staging light
I am sure this issue is on here, but after searching for the past hour I can't find the answers I am looking for, so you have to forgive me if this is a common issue/ topic.
Anyway, car facts: 98 Trans Am with slotted rotors, hawk pads, stock calipers, 3400 stall, MT Drag radials. My brakes are not holding at the staging light when I load the car, so I don't load the stall as much, so I don't roll, etc.
After bleeding the brakes a few times, my braking issue still persists. I can't see it being a brake caliper issue as all four are fine. I unhooked the ABS and the issue still happened. I am starting to think I may have a brake master cylinder issue, but I am not sure.
Any thoughts would be appreciated.
Thanks
Skentch is offline   Reply With Quote
Old 03-31-2012, 05:48 PM   #2
01ssreda4's Avatar
Any aftermarket stall can push through the brakes at the track on an ET Street. How is the actual braking performance of the car?
01ssreda4 is offline   Reply With Quote
Old 03-31-2012, 06:20 PM   #3
Skentch's Avatar
The braking performance of the car seems to be fine when I drive around town and on the highway.
Old 03-31-2012, 06:22 PM   #4
jsteele90's Avatar
your brakes are fine. you dont need to brake torque the car so much that it pushes through the beams anyway. my car gets the best 60ft times launching at around 1500 rpm.
jsteele90 is offline   Reply With Quote
Old 03-31-2012, 06:34 PM   #5
Skentch's Avatar
So question then, if I put in a bigger converter will it let me load up to a higher RPM before the brakes start to push?
Old 04-01-2012, 09:19 AM   #6
01ssreda4's Avatar
Most likely yes it will.
Old 04-01-2012, 02:09 PM   #7
FirstYrLS1Z's Avatar
^^^agree.
higher stall = more slippage = higher rpm before it pushes thru brakes.
also means higher flash rpm = higher convertor 'engagement'.
FirstYrLS1Z is offline   Reply With Quote
Old 04-01-2012, 05:57 PM   #8
Skentch's Avatar
That's good to know as I was looking into a higher stall and possibly a trans lock. Thanks for the info.
Related Topics
Thread Thread Starter Forum Replies Last Post
Brake line opinions vroom_vroom Cadillac CTS-V 2004-2007 (Gen I) 31 01-03-2017 12:32 AM
CTS-V Calipers and 2010 Camaro SS Rotors TURBO6.0L Suspension & Brakes 131 11-27-2016 01:53 AM
Need TH400 Help... FEAR LS Automatic Transmission 6 02-27-2015 12:58 AM
Brake Moan Noise Austinma62 Suspension & Brakes 2 01-08-2013 12:00 PM
Seriously need Help to get my F'in Brakes to work, itching to drive my 383 zbomb5610 LT1-LT4 Modifications 19 07-18-2010 11:08 AM
Tags
brake, brakes, camaro, car, drag, holding, line, ls1, ls1tech, pushing, staging, translock, uphill, vn780
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
