Help w/ removig torque arm and bushing - LS1TECH
Thread Tools Search this Thread
Old 04-03-2012, 07:18 PM   #1
chevystyle's Avatar
Default Help w/ removig torque arm and bushing
Do I need to let the axle hang (frame on jack stands) or just back the Camaro up onto ramps and keep the weight on the suspension??
Also, how to do an R&R on the new poly bushing??
Thanks.
chevystyle is offline   Reply With Quote
Old 04-03-2012, 07:27 PM   #2
When I did mine I used a lift and unbolted it then had to use a screw jack to take the tenson off the TA, then you kinda gotta twist and pull to get of out. As far as the mount its a bitch 3 bolts on tail of transmissions. If u can unbolt the trans crossmember and lower the trans a lil bit might make it easier
96RamAirTA is offline   Reply With Quote
Old 04-03-2012, 09:59 PM   #3
need4fun2469's Avatar
I let my axle hang when I swapped mine out. I trimmed some of the poly mount to allow the clam shell to close around it.
need4fun2469 is offline   Reply With Quote
Related Topics
Thread Thread Starter Forum Replies Last Post
Need your help identifying these LCAs!!!!!!! lildemars09 Suspension & Brakes 3 06-30-2016 11:28 AM
Torque arm removing and bushing replacement help. chevystyle Suspension & Brakes 15 03-23-2016 11:14 AM
Suspension / Alignment shop in Jax? juSStin4171 Florida Members 2 08-16-2013 09:28 PM
Stock trailing arms with spherical bushings silver1r Cadillac CTS-V 2004-2007 (Gen I) 16 03-26-2013 10:31 PM
sway bar bushing size NicB Suspension & Brakes 4 05-08-2012 12:28 AM
Tags
a4, arm, bushing, buy, ls1tech, missing, problems, squeeking, ta, torque, writeup, ws6
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
