Reduce 60ft
Old 04-12-2012, 11:27 PM
cory32690's Avatar
Default Reduce 60ft
01 formula a4 4k stalk 3.23 gear
Has umi tubular control arms and pan hard bar with lca relocation brackets and a set up subframe connectors rest of Suspension is stock stock motor besides long tubes and ory with dump and a lid nitto 245/50/16 nt555r
Last track outing best
60ft: 1.73
1/8th :7.96
Mph 86.6
Old 04-13-2012, 08:06 AM
UMI Sales's Avatar
Hey Cory. Are you asking what to do next?
If so, how about a torque arm and new front shocks?...
ramey
Old 04-13-2012, 08:19 AM
LS1Tech Premium Sponsor
BMR Sales2's Avatar
Is the car spinning off the line at all or are you dead hooking? A 1.73 60ft isnt bad on those little Nitto NT555R drag radials. If you are dead hooking then you will need to add some power to get the 60ft down some more. If you are spinning then I would look at using a better drag radial and few suspension pieces like a torque arm and shocks would help you out.
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Old 04-13-2012, 08:25 AM
JKB315's Avatar
Times are close to mine . My best time is 7.98 1.74 60 foot @86.02 I don t have headers . Stock motor eith lid .Just a basinni ory . I have a 3600 stall and Bmr lca and umi relocation brackets on a s60 with 3 73 gears. Along with a spohn torque arm. Toyo proxies drag radials. No subframes though. Getting heAders today. Not sure how well they ll help. And I have subframes I need welded on. I would be interested in learning how to lower my 60 foot as well . I am still new to racing so maybe my launch tecnique needs improved.
Old 04-14-2012, 12:01 AM
cory32690's Avatar
It spins hard still I can only get 2800 in the stall or it while light them up also tried flashing it went a 2.3 60ft everyone was saying i was spinning pretty hard
Old 04-14-2012, 12:03 AM
cory32690's Avatar
Also should I try adjusting the control arm positions on the brackets it all the way on bottom hole
Old 04-14-2012, 03:01 AM
01ssreda4's Avatar
You need better tires dood.....
Old 04-14-2012, 11:45 AM
cory32690's Avatar
That's what I'm thinking took it to the track last night and could only get 8.08 at 86.4 on a 1.82 60ft I only got two passes because of rain
Old 04-15-2012, 01:25 AM
Dave_the_SS's Avatar
cory i ran in to pretty much the same issue u were but my 60 was much worse.lol
i run a 325/50/15 nitto nt555r on a stock 3.23 gear (cars A4)
mods
bbk intake & tb
ms3
longtubes
truduals
fti lid
3600 stall
suspension i only have adj. pan hard and lcas.
i tried foot braking and odd as it sounds i was doing 2.1 60ft's
and when flashing it i was getting 2.07 60's
so yeah id say swap tires. i know i wasnt hooking for spit. i was spinning so bad i was coming out of the groove off the line.
had tires down at at 13 psi when i was doing my best 60's
Old 04-15-2012, 01:34 AM
arob987's Avatar
nitto drags suck on the track,
Old 04-15-2012, 11:03 PM
cory32690's Avatar
They fill lIke they hook better on the street than the track and I'm doing long burnouts and on as low as 12psi In them
Old 04-15-2012, 11:30 PM
504ls1's Avatar
I had the 555r's and was able to get a 1.67 out of them. 315/35/17 on a cammed car. Stalled it to about 2400 on the foot brake. Stock rear suspension besides adjustable shocks. I ran them at about 22 psi, when I went lower than that I usually spun more. Like everyone else is saying it might be time for a better drag radial. I have some m/t's on the way to try to help my times.
Old 04-16-2012, 07:55 AM
BMR Sales2's Avatar
Better tires would be where I would start. Changing the lower control arm mounting position on the rear may also help a little bit. You could try moving it up one hole which would keep it from hitting the tire so hard and possibly allow you to stall the car a little higher off the line.
__________________
Glenn ***
Sales Tech
813.986.9302
Old 04-16-2012, 07:57 AM
soco80p's Avatar
Drag slicks
Old 04-16-2012, 09:23 PM
cory32690's Avatar
No slick drag radials only for me I'm gonna have to go with mickey Thompson 255/50/16
Old 04-17-2012, 09:07 AM
BMR Tech2's Avatar
Also, never underestimate the power of weight reduction. The rear seat, spare tire/jack, front sway bar, and a few other items are extremely easy to remove and will take out 50-75lbs from the car. Every 100lbs is roughly worth a .10 in the quarter. The reduced weight also means it's easier for the car to launch so you will see an improvement in your short times.
- Kevin
__________________
T.C.
Sales Pro
BMR Suspension
(813) 986-9302
Like us on Facebook!
Old 04-17-2012, 09:22 AM
JKB315's Avatar
- Kevin
I am actually doing just that. I removed the spare tire and jack last outting. This time I am doing rear seats, maybe passenger seat, removing dead ac compressor and I am going from a stock z28 hood to a no name aftermarket ss hood. And I am unbolting the sway bar.
If the original poster doesn't mind, I'll post my results here to back up what you're saying about weight reduction. This thread interests me since we're so close time wise. I am getting another set of runs in with this weight reduction before I put my headers on in a few weeks.
I am still fighting a slight drivetrain vibration due to incorrect pinion angle I hope. I hope to reset it right today. Been fighting it since my s60 install. I had it almost gone at one point then I decided to improve it and made it worse.
Old 04-17-2012, 09:37 AM
JKB315's Avatar
Do you guys go through the water with these tires? My best 60 foot of 1.74 was when I backed up into the water box and really heated them. (track has rear wall, have to back into water box) I have toyo proxies drag radials. If I did back to back runs, they got too hot and spun. I am saving for some m/t's.
Old 04-18-2012, 07:46 PM
cory32690's Avatar
I went down last Friday again with back seats out random junk and tools was about 50-60 Pounds I already have jack and spare out of car still has front sway bar but last Friday best
1.83 60ft
8.01 @86.8
And I don't get in the water and I tried all kinds of diff tire pressures started at 30 and went down the lower I go the better does best at 12psi for sure
Old 04-19-2012, 07:54 AM
BMR Sales2's Avatar
1.83 60ft
8.01 @86.8
Did you have issues with the tires spinning and how high were stalling the car up when launching?
__________________
Glenn ***
Sales Tech
813.986.9302
Quick Reply: Reduce 60ft
