Hotchkis Subframe Connectors - LS1TECH
Thread Tools Search this Thread
Old 04-18-2012, 10:23 AM   #1
DNTBJELOUS's Avatar
Default Hotchkis Subframe Connectors
Anyone have any expeirence welding these guys into an F-Body?
I just picked up a set yesterday and am reading the instructions off the Hotchkis website. Seems pretty straight forward. Does anyone have any input on this? Anything that might be different from the instructions that anyone has ran into? Also how is the performance after they are installed?
DNTBJELOUS is offline   Reply With Quote
Old 04-18-2012, 11:21 AM   #2
Its for structural rigidity your not gonna feel a whole lot. Make sure you know how to lay down a nice bead. if they were to fall off while driving you could create an ancient machine called the catapult and experience a whole new world of g forces u never dreamed of.
License2Ill is offline   Reply With Quote
Old 04-18-2012, 11:39 AM   #3
DNTBJELOUS's Avatar
Yeah absolutely I almost don't care if it looks super pretty underneath. As long as it's held on GOOD.
Old 04-18-2012, 11:55 AM   #4
You'll feel slightly on high bank curves....make sure to penetrate and your gold. Etch primer then spray over. Upgrade both your sway bars you'll really feel it all come together then.
Old 04-18-2012, 12:46 PM   #5
DNTBJELOUS's Avatar
Next suspension stuff I'm going to get going on would be the relocation brackets for the control arms as well as springs and shocks. So I'm sure I'll feel a difference with that. I'll post up again here over the weekend after I install them though!
Old 04-18-2012, 08:27 PM   #6
You will also want to have the cars weight on the tires when you weld them in as well.
bowtiedad_z28 is offline   Reply With Quote
Old 04-19-2012, 11:24 AM   #7
DNTBJELOUS's Avatar
Quote:
So just have the front end jacked up then?
Does anyone know of any videos anyone has ever made putting these in or any type of install threads?
Old 04-19-2012, 12:26 PM   #8
z28bryan's Avatar
The Hotchkis boxed subframe connectors were my first overall modification I ever did for my Camaro way back in the day
Did I feel anything? I'm not really sure. I added these on way back when I didn't know $hit about modifying my car. Didn't matter.. I still had the crappy stock shocks. Basically swaybars, springs, shocks have a lot of effect on handling. Compared to those, subframe connectors have almost no effect on handling.
They do make good jackpoints though. I jack the whole side of my car up 1-2 feet from the middle of the SFCs without any problem.
z28bryan is offline   Reply With Quote
Related Topics
Thread Thread Starter Forum Replies Last Post
Hotchkis Springs LS1 VS LT1 2000WhiteTA Suspension & Brakes 1 03-03-2012 05:53 PM
ls2 68 camaro hotchkis lowering springs? ride? and height? firehawk68mcleod Conversions & Hybrids 5 06-24-2011 09:36 PM
Opinions on Hotchkis springs for 98-02 F-body rob69zombie Suspension & Brakes 8 01-19-2011 10:19 PM
Hotchkis rear swaybar... ss.slp.ls1 LT1-LT4 Modifications 1 03-31-2009 08:42 PM
pics of Koni shocks and stock/hotchkis springs Screamin_Z Suspension & Brakes 22 06-08-2006 12:56 PM
Tags
2010, camaro, connector, connectors, expect, frame, hotchkis, install, ls1, ls1tech, review, sbfc, slp, subframe, video, welding
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
